NAS 326 fan speed
Duplex
Hi
Could someone direct me to the thread for fan speed on these things please i couldn't find one and cant believe no one else has asked this as the fan speed turns at max revolution and is way too loud and unnecessary, i have swapped out the fan and its still the same, How do i make the fan speed less by command line please. I cant use it because of this.
well after research apparently not by software as it 3 pin only. probably have to solder a resistor or something in to lower the voltage to it0
3 wires is enough for software regulation. 1 ground, 1 pwm and 1 index. Problem is that I never has a 326 in my hands, so I couldn't study the way the fan is regulated.On the 310 it's a daemon in userspace, on all other NSA3xx models you could only read the rpm, but the fan speed was regulated by some microcontroller.On the 500 series it is a daemon in userspace, which can be tweaked, but for the NAS326 I don't know.0
Looks weird to me. I have 2 different 326 and both are very quiet. If i can hear something, then its harddrive not fan ...
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
