Armor G1 poor performance :(
Groose Gott @LeMac
According to the Armor G1's Wireless Speed specifications at https://www.zyxel.com/products_services/AC2600-Multi-Gigabit-WiFi-Router-ARMOR-G1/specifications it suggests that in 2.4GHz band that it can do 800MBits/s IF channel bandwidth is set to 40MHz + 1733 MBits/s in 5GHz band IF channel bandwidth is set to 80MHz.
Kind regards,
Tony0 -
Hallo Tony,tonygibbs16 said:Groose Gott @LeMac
Kind regards,
Tonythat does not work unfortunately.Thank you for your support.Greeting1 -
Hello @LeMac
At 1 metre distance, the WiFi receiver might be being overloaded.
At what distance do you get the higher speed of 247.15MBps?
I wonder what the 8K or 4K means? could it mean that that channel bandwidth has changed?
If you set SSID for 5GHz and 2.4GHz band to different values, then can you confirm that you are using 802.11ac in 5GHz band?
Kind regards,
Tony0 -
tonygibbs16 said:Hello @LeMac
Kind regards,
TonyHi Tony, I assume that 8K and 4K means what you can stream with it.Yes I use 802.11ac in the 5 GHz band. On the phone I get a link speed of 866 mbit, on the pc the same.I can not find the error.Yes I use 802.11ac in the 5 GHz band. On the phone I get a link speed of 866 mbit, on the pc the same.I can not find the error. I think it's the router hardware.The speeds on the pc and on the cell phone are identically bad.1 -
Hi Tony, even 300 mbit are in the same room is too slow when advertised with 2600. I have a 500 mbit line and that should also be achieved. In the future I have 1000 mbit and the router should also be able to transmit. What is the 2.5 gb lan connection for if it can not handle such speeds?tonygibbs16 said:Groose Gott and Hello @LeMac
According to the Armor G1 user guide at https://www.zyxel.com/support/download_landing/product/armor_g1_22.shtml?c=gb&l=en&pid=20200121174129&tab=User_s_Guide seems like you always have to have both 2.4GHz and 5GHz WiFi enabled at the same time.
- you can give them different SSID though, or it can be the same.
To get the 300Mbits speed on WiFi, you need to set the WiFi bandwidth to 40MHz see https://www.bitfeed.co/page/wifi-20-mhz-or-40-mhz-how-to-choose-the-bandwidth and hope that there is enough channels available.
I hope that this is helpful.
Kind regards,
Tonytonygibbs16 sagte:Groose Gott und Hello @LeMac
Laut dem Armor G1-Benutzerhandbuch unter https://www.zyxel.com/support/download_landing/product/armor_g1_22.shtml?c=gb&l=de&pid=20200121174129&tab=User_s_Guide müssen Sie dies immer haben Sowohl 2,4 GHz als auch 5 GHz WiFi sind gleichzeitig aktiviert.
- Sie können ihnen jedoch eine andere SSID geben, oder es kann dieselbe sein.
Um die 300-Mbit-Geschwindigkeit über WLAN zu erreichen, müssen Sie die WLAN-Bandbreite auf 40 MHz einstellen (siehe https://www.bitfeed.co/page/wifi-20-mhz-or-40-mhz-how-to-choose-the- Bandbreite und hoffe, dass genügend Kanäle verfügbar sind.
Ich hoffe das ist hilfreich.
Herzliche Grüße,
Tony
Hallo Tony, is 300 mbit the maximum that can be achieved with the Amor g1?tonygibbs16 sagte:Groose Gott und Hallo @LeMac
Laut DM Rüstung G1-Benutzerhandbuch unter https://www.zyxel.com/support/download_landing/product/armor_g1_22.shtml?c=gb&l=de&pid=20200121174129&tab=User_s_Guide Müssen Sie sterben immer HAT Sowohl 2, 4 GHz als auch 5 GHz WiFi sind erforderlich.
- Sie können ihre eine andere SSID geben, oder es kann sein sein.
Um die 300-Mbit-Rechte über WLAN zu ändern, müssen Sie die WLAN-Bandbreite auf 40 MHz prüfen (siehe https://www.bitfeed.co/page/wifi-20-mhz-or-40-mhz-how- Die Bandbreite und die Rechte, die sich gehört, sind.
Ich habe das gehört.
Herzliche Grüße,
Tony0 -
- 588 USG FLEX H Series
- 477 News and Release
