WDS problem and workaround.
  • Zyxel_Freda
    Zyxel_Freda Posts: 397  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @PeterUK
    Thanks for your information. We'll check it and reply to you asap.
    PeterUK Posts: 4,044  Guru Member
    So I see V6.10(ABTF.10) in USG60W for the WAX510D which got updated (their was a problem downloading said AP firmware download failed. Reason: Device storage is not enough (which there is free space) so it removed one of the downloaded AP to download the WAX510D.
    I will have to wait for 6.10(ABIN.10) NWA1123-AC HD? To show up on the web site to install.
    With NWA1123-AC HD still on 6.10(ABIN.8)C0 and a reboot the WDS link didn't happen to WAX510D new firmware so might get fixed when I update the NWA1123-AC HD?
    Had a issue before the update on the NWA1123-AC HD with a long uptime stops broadcasting its SSID and needed to be rebooted along with the WAX510D.
  • Zyxel_Tobias
    Zyxel_Tobias Posts: 208  Zyxel Employee
    Hi @PeterUK,
    Freda is out for a few days, but we will come back to you quite soon on that topic.
    Kind Regards,
    Tobias
    Thanks I was just update this topic to see if the new firmware fixes the issues.
    When the WDS and  Repeater works then stop working seems to happen based on DCS Time Interval set to 720.
    edited February 2021
    Tried setting both Radio 2 AP root and Repeater to manual channel and the WDS link still dropped out and needing AP root to be rebooted.
  • Zyxel_CSO
    Zyxel_CSO Posts: 481  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    Hi @PeterUK,
    We checked the diagnostic you provided to us and actually the root and repeater were connected when you collect the info. So, we'll keep checking the detail of the log about the Internet access issue. BTW, may I know how did you check the connection of the mesh?
    Zyxel Nebula Support
    Hi interesting you say root and repeater were connected as the problem happened again done a Diagnostics Collect if needed I then logged in to WAX510D and found WDS downlink info as linked but the Repeater still don't work only a reboot of the WAX510D or changing the radio 2 channel gets the mesh working again.
    I can tell the mesh goes down for the Repeater by SSID not the same as AP root and when I connect to the repeater I get stuck in obtaining IP that and I can't log in to the repeater.
  • Zyxel_CSO
    Hi @PeterUK
    It's recommended to disable the DCS when building the mesh of APs because it might make the repeater disconnected when channel changed.
    We'll keep checking the detail of the diagnostic info that you provided to us.
    I tired that it didn't help
    WDS problem and workaround. - Page 2 — Zyxel
