Secondary Multys suddenly no longer connecting
Manny67
After a power cut I managed to reboot my primary multi but the other 3 secondary multis will not reconnect despite having worked perfectly before the power cut. I ended up deleting my network and starting over, and although the primary multy works again, none of the others will blink blue after connecting to power. They blink white for a few minutes before settling on solid red. Any thoughts or suggestions gratefully received.
Hi Manny,
welcome to community forum.
You may reset the Multy (press reset button 10 seconds) to let devices back to system default config and try configure it from scratch again, if it didn´t blink blue for Bluetooth connection.
Kind Regards,
Tobias0
Hi Manny,
Kind Regards,
Tobias0 -
Hi Tobias,
Many thanks for your reply. That worked!
Best wishes, M1
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
