NAS540 First one degraded disk, now volume gone.
Kuno
Hi
I have a bit of a problem.
I have had a degraded disk for some time, but now the volume have crashed.
I pushed the "Reinitialise" button in disk management, and now I have two hot spare disks, and no volume.
I have read this post https://community.zyxel.com/en/discussion/6325/nas540-raid5-crash-gt-volume-lost
and was hoping I could get one more disk online, so I could put a new disk in and repair.
I have run these commands:
cat /proc/mdstat
cat /proc/mdstat
cat /proc/partitions
cat /proc/mounts
su
mdadm --examine /dev/sd[abcdef]3
And here is the result:
Sorry for the long post. Any help will be very much appreciated.
Yours sincerly
Lars.
~ $ cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : inactive sdb3[0](S) sdf3[3](S)
7805773824 blocks super 1.2
md1 : active raid1 sdb2[0] sdf2[3] sdc2[1]
1998784 blocks super 1.2 [4/3] [UU_U]
md0 : active raid1 sdb1[0] sdf1[3] sdc1[1]
1997760 blocks super 1.2 [4/3] [UU_U]
unused devices: <none>
~ $ cat /proc/partitions
major minor #blocks name
7 0 147456 loop0
31 0 256 mtdblock0
31 1 512 mtdblock1
31 2 256 mtdblock2
31 3 10240 mtdblock3
31 4 10240 mtdblock4
31 5 112640 mtdblock5
31 6 10240 mtdblock6
31 7 112640 mtdblock7
31 8 6144 mtdblock8
8 0 1465138584 sda
8 1 1465138550 sda1
8 16 3907018584 sdb
8 17 1998848 sdb1
8 18 1999872 sdb2
8 19 3903017984 sdb3
8 32 3907018584 sdc
8 33 1998848 sdc1
8 34 1999872 sdc2
8 35 3903017984 sdc3
8 48 2930264064 sdd
8 49 2930264030 sdd1
8 64 4044975 sde
8 80 3907018584 sdf
8 81 1998848 sdf1
8 82 1999872 sdf2
8 83 3903017984 sdf3
31 9 102424 mtdblock9
9 0 1997760 md0
9 1 1998784 md1
31 10 4464 mtdblock10
~ $ cat /proc/mounts
rootfs / rootfs rw 0 0
/proc /proc proc rw,relatime 0 0
/sys /sys sysfs rw,relatime 0 0
none /proc/bus/usb usbfs rw,relatime 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
ubi7:ubi_rootfs2 /firmware/mnt/nand ubifs ro,relatime 0 0
/dev/md0 /firmware/mnt/sysdisk ext4 ro,relatime,user_xattr,barrier=1,data=ordered 0 0
/dev/loop0 /ram_bin ext2 ro,relatime,user_xattr,barrier=1 0 0
/dev/loop0 /usr ext2 ro,relatime,user_xattr,barrier=1 0 0
/dev/loop0 /lib/security ext2 ro,relatime,user_xattr,barrier=1 0 0
/dev/loop0 /lib/modules ext2 ro,relatime,user_xattr,barrier=1 0 0
/dev/loop0 /lib/locale ext2 ro,relatime,user_xattr,barrier=1 0 0
/dev/ram0 /tmp/tmpfs tmpfs rw,relatime,size=5120k 0 0
/dev/ram0 /usr/local/etc tmpfs rw,relatime,size=5120k 0 0
ubi3:ubi_config /etc/zyxel ubifs rw,relatime 0 0
/dev/sda1 /e-data/74039e2c2d0d922fad13bf0c6334d20d tntfs rw,relatime,uid=99,gid=0,umask=00,nls=utf8,min_prealloc_size=64k,max_prealloc_size=1465138548,readahead=4M,user_xattr,case_sensitive,fail_safe,hidden=show,dotfile=show,errors=continue,mft_zone_multiplier=1 0 0
configfs /sys/kernel/config configfs rw,relatime 0 0
/dev/sdd1 /e-data/99984a75a6099187884410a8c3dc23cc tntfs rw,relatime,uid=99,gid=0,umask=00,nls=utf8,min_prealloc_size=64k,max_prealloc_size=2930264028,readahead=4M,user_xattr,case_sensitive,reset_journal,fail_safe,hidden=show,dotfile=show,errors=continue,mft_zone_multiplier=1 0 0
~ # mdadm --examine /dev/sd[abcdef]3
mdadm: cannot open /dev/sda3: No such device or address
/dev/sdb3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 47bf8f23:7fad834c:1e963868:2f92844e
Name : NAS540:2 (local to host NAS540)
Creation Time : Fri Nov 20 23:22:39 2015
Raid Level : raid5
Raid Devices : 4
Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)
Array Size : 11708660736 (11166.25 GiB 11989.67 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
State : clean
Device UUID : 7e94d1ab:bd4bcda4:a3b3f2d3:33b4f07c
Update Time : Wed Feb 3 17:06:03 2021
Checksum : 31ca9026 - correct
Events : 473740
Layout : left-symmetric
Chunk Size : 64K
Device Role : Active device 0
Array State : A..A ('A' == active, '.' == missing)
/dev/sdc3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x2
Raid Level : raid5
Raid Devices : 4
Array Size : 11708660160 (11166.25 GiB 11989.67 GB)
Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)
Recovery Offset : 487860848 sectors
State : active
Device UUID : c8bfbe19:b1e8071a:6847d69e:ac94f267
Update Time : Fri Jun 19 13:29:30 2020
Checksum : e6b533e4 - correct
Events : 37652
Chunk Size : 64K
Device Role : Active device 1
Array State : AAAA ('A' == active, '.' == missing)
mdadm: cannot open /dev/sdd3: No such device or address
mdadm: cannot open /dev/sde3: No such device or address
/dev/sdf3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
Raid Devices : 4
State : clean
Device UUID : ad37fb23:abd08ef6:c18140b4:92cbcbe9
Checksum : 48dea373 - correct
Events : 473740
Chunk Size : 64K
Device Role : Active device 3
Yours sincerly
Lars.
Do you use that NAS a lot? The problem is, sdc3 is dropped from the array at 19 june 2020, while the array went down at 3 february 2021. So the pieces won't 'fit' anymore. If the NAS was not in use that time, it might be possible to rebuild the array, but if you normally used it, you'll have corrupted files and a corrupted filesystem.
I mostly read from it, not a lot of writing.0
Well, you can try. Everything you wrote after 19 june 2020 can be considered lost. Even if the file seems to be there, when it's bigger than 128kB it is not possible that it's not corrupted.
It is possible that the array will be read only, as the default action on detection of a corrupt filesystem is to remount it read only.
sdb3 is active device 0, sdc3 is active device 1, and sdf3 is active device 3. So device 2 is missing. The command to rebuild the array is
mdadm --stop /dev/md2mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata=1.2 --chunk=64K --layout=left-symmetric /dev/md2 /dev/sdb3 /dev/sdc3 missing /dev/sdf3(that are two lines, both starting with mdadm)It is possible that the first command will error out. /proc/mdstat shows /dev/md2, and it's a bit fuzzy if you have to stop it or not, in that case.
I now have md2 as an active raid5 array.md2 : active raid5 sdf3[3] sdc3[1] sdb3[0]11708660160 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [UU_U]Can I replace the missing disk whit a new disk? And is there a way to see witch psycical disk it is, that is missing?
And thanks a lot for your help.
How do I mount the the array again? When I go into the Zyxel control panel, it says "please insert disk before making an volume".
You can mount the array bymkdir /mnt/mountpointmount /dev/md2 /mnt/mountpointBut the box should automount on a reboot. Of course it's possible that severe filesystem errors will prevent an automount (or a mount).Can I replace the missing disk whit a new disk?Yes, but I don't recommend it. You array has a corrupted filesystem, and I don't know if filesystem repair tools will be able to repair that. If you add redundancy (a 4th disk) you will simply make your corrupt filesystem redundant. You'd better backup all files (you need a backup anyway), delete the volume and create a new one. Then put the files back. I think that's the only reliable way to get a consistent filesystem again.When you do want to add redundancy, the webinterface will off you to rebuild the array as soon as the volume is recognized and you inserted a new disk.And is there a way to see witch psycical disk it is, that is missing?Don't the LED's show it? Or the webinterface? My guess is that it's the 3th disk, as the third device is missing in the array. The array is originally built in sequence. But after that you can shuffle the disks without problems, so that is no guarantee.The disk is no longer part of any array, nor does it show up (recognizably) in /proc/partitions, so it's dead.After some time of disk access I'd expect it to be the coldest one, or the hottest one, depending on how it is dead. In both cases it should clearly deviate from the others.If needed you can test all disks outside the box. I expect one of the disks to be not recognized, or wrongly recognized. (Your disk sde is not mounted, and 4GB in size. So that is an SD cart or USB stick without (supported) filesystem, or the remains of your dead disk.)0
I will do as you suggest and get all of the NAS and then make a new array with a new disk.
Thanks a lot for all your help.0 -
Hi again.
When I try to mount I get this message:
mount: wrong fs type, bad option, bad superblock on /dev/md2,
Can you post the output ofmdadm --examine /dev/sd[abcdef]3cat /proc/partitions0
Here is the output:dadm --examine /dev/sd[abcdef]3 :/dev/sda3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 3f54cc40:f80a2eac:852f5bc9:9218f078Name : NAS540:2 (local to host NAS540)Creation Time : Sat Feb 13 20:26:51 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660160 (11166.25 GiB 11989.67 GB)Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 099f93b9:acf2b940:6a8b7a58:8d5024dbUpdate Time : Sat Feb 27 22:23:47 2021Checksum : d09e053f - correctEvents : 12Layout : left-symmetricChunk Size : 64KDevice Role : Active device 0Array State : AA.A ('A' == active, '.' == missing)/dev/sdb3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 3f54cc40:f80a2eac:852f5bc9:9218f078Name : NAS540:2 (local to host NAS540)Creation Time : Sat Feb 13 20:26:51 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660160 (11166.25 GiB 11989.67 GB)Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 8946215f:abe55fac:5da49137:a5bf5ebfUpdate Time : Sat Feb 27 22:23:47 2021Checksum : a52327ca - correctEvents : 12Layout : left-symmetricChunk Size : 64KDevice Role : Active device 1Array State : AA.A ('A' == active, '.' == missing)mdadm: cannot open /dev/sdc3: No such device or address/dev/sdd3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 3f54cc40:f80a2eac:852f5bc9:9218f078Name : NAS540:2 (local to host NAS540)Creation Time : Sat Feb 13 20:26:51 2021Raid Level : raid5Raid Devices : 4Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)Array Size : 11708660160 (11166.25 GiB 11989.67 GB)Used Dev Size : 7805773440 (3722.08 GiB 3996.56 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 429dc1d1:89752749:17a9583f:eb883655Update Time : Sat Feb 27 22:23:47 2021Checksum : 5229dc63 - correctEvents : 12Layout : left-symmetricChunk Size : 64KDevice Role : Active device 3Array State : AA.A ('A' == active, '.' == missing)mdadm: cannot open /dev/sde3: No such device or addressmdadm: cannot open /dev/sdf3: No such device or addresscat /proc/partitions :major minor #blocks name7 0 147456 loop031 0 256 mtdblock031 1 512 mtdblock131 2 256 mtdblock231 3 10240 mtdblock331 4 10240 mtdblock431 5 112640 mtdblock531 6 10240 mtdblock631 7 112640 mtdblock731 8 6144 mtdblock88 0 3907018584 sda8 1 1998848 sda18 2 1999872 sda28 3 3903017984 sda38 16 3907018584 sdb8 17 1998848 sdb18 18 1999872 sdb28 19 3903017984 sdb38 32 4044975 sdc8 48 3907018584 sdd8 49 1998848 sdd18 50 1999872 sdd28 51 3903017984 sdd331 9 102424 mtdblock99 0 1997760 md09 1 1998784 md131 10 4464 mtdblock109 2 11708660160 md2
And again, thank you very much for all you help.
Lars0
- 588 USG FLEX H Series
- 476 News and Release
