Issue installing Entware on NAS540 from Github wiki
I really don't know how you manage to get that all in USRPKG_DEPS_START. I suppose you copy@paste too much.What if you just executeecho entware > /i-data/.system/zy-pkgs/USRPKG_DEPS_START
The instructions are confusing, there really is no need to include this section:
touch /i-data/.system/zy-pkgs/USRPKG_DEPS_START chmod +x /i-data/.system/zy-pkgs/USRPKG_DEPS_START echo entware > /i-data/.system/zy-pkgs/USRPKG_DEPS_START
It makes it look like that it is what the contents of the USRPKG_DEPS_START needs to be. It should just haveentware
The other part that is ambiguous is/are the shutdown script(s), I assumed that those are two different scripts. So I created each one separately. Was I supposed to copy the code and paste it in as one command to create the script(s)?
When I run:
Nothing appears to happen, I just get a new command line. After reboot, mount returns the opt file path! But when I try to opkg update I get a wget error: opkg_download: Failed to download http://bin.entware.net/armv7sf-k3.2/Packages.gz, wget returned 1.
I rebooted again and mount does not return the opt file path and opkg update say opkg: not found
I ran echo entware > /i-data/.system/zy-pkgs/USRPKG_DEPS_START again and rebooted and the path came back and I was able to execute opkg commands. But again on reboot it's gone, including the opt dir that had been there.
Does USRPKG_DEPS_START still exist, and contain entware? If not, does either the start- or the stopscript contain a command to remove/adapt that file?
Many attempts to get this going, but I can't get any persistence. For some reason every third boot overwrites the content of USRPKG_DEPS_START and breaks the install. My workaround is before a reboot I always check USRPKG_DEPS_START and edit if necessary.
I don't see anything in either the start or stop script that would remove or adapt the file. What could make this old file reappear after a couple of reboots?
Thanks again for all your help, couldn't have gotten this far without it.0 -
Strange. The automatic update daemon might be responsible for this, but I don't see how. You can try to disable it, to see if it solves the issue.If you feel nosy you can write a script using inotifywait to detect which process is responsible for deleting the file.BTW, it doesn't hurt to let the shutdown script unconditionally overwrite the USRPKG_DEPS_START. Why check first if it is needed?
Sorry, I'm out of my depth a bit here. When you say the shutdown script, do you mean the sdentware file from the guide?
#!/bin/sh /opt/etc/init.d/rc.unslung stop
Are you saying overwrite the USRPKG_DEPS_START file in the shutdown script, would I add this as a line?echo entware > /i-data/.system/zy-pkgs/USRPKG_DEPS_START
Thanks again!0 -
Indeed.
@gsshelton - Did you get this to work? I seem to have the same challenge installing Entware on the 542.
solved it. didnt know we had to remove <> from things. :P
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
