LTE4506-M606 - V1.00(ABDO.6)C0 - Internet access down after LTE renew connection from SFR
pbt
I updated this Saturday from V1.00(ABDO.4)C0 to V1.00(ABDO.6)C0 and I lost Internet connection after the reboot. DNS resolution was OK, but Internet sites access DOWN. Reboot again fropm the GUI, then Internet sites connections were UP. I got the same error today after a reset from SFR (changing the connection on their side), then Internet sites connections DOWN and I did the same procedure: reboot the LTE4506-M606 (from the GUI).
I think I will do a roolback from V1.00(ABDO.6)C0 to V1.00(ABDO.4)C0, with this version, I never get that strange issue.
I don't know how to reset the LTE connection with SFR on my side, with the GUI or CLI.
Any idea ?
Any idea ?
Hello @pbtI think that you could reselect the SFR manually as the Public Land Mobile Network (PLMN) following the procedure in section 4.5 of the user guide at ftp://ftp.zyxel.com/LTE4506-M606/user_guide/LTE4506-M606_V1.0.pdfThis might do the Wireless WAN connection reset that you are after.I hope that this is helpful.Kind regards,Tony
hello Tony,
I will try this.
But I think the issue is in the SFR Network, because I got it a few hour ago. I do nothing, and the Internet is working now normally.
Many thanks !0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
