Multy X goes "offline"
ZyxelRichard
ZyxelRichard Posts: 3 image  Freshman Member
First Anniversary
I have a network of 4 X Multy X (one at each corner of my house about 50 feet apart. The primary Multy is in my study. The Lounge unit regularly, but at random intervals, goes offline (a message on the Multy App states "Offline, please check the power connection). I have to switch off and then back on and wait about 10 minutes for it to reconnect. I have swapped the units from another room but it still happens in the Lounge. Any ideas?
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    edited March 2021
    Hi  ZyxelRichard,
    1 .Please kindly provide your network topology.
    2. Could you describe more details about your issue?
       (1) How often does the symptoms happen on the Lounge?
    3. Please send us the feedback on the Multy App.
       When pressing the Send feedback button on the Multy APP, it will auto generate the logs of the device, please send the log        file to us.
    Best regards,
    Jerry
  • Schemco
    Schemco Posts: 3
    I ve had very similar situation and quick and easy fix was full reset of router node and satelites. I used new account in app to create new mesh and everything went back to normal where as earlier there was red-green light on nodes every couple hours and offline status of them in app
