[NEBULA] Set privilege for administrators
Hello!
I want to set privilege for some accounts, and I hope some of them can just view the reports, data etc. without the right for configuration. While I found there are several Privilege Levels, so what's the different between them? Monitor only, ready only, guest ambassador?
Thank you!
Thank you!
I am bug.
Hi IAMBug
We have two types of privilege levels on Organization before granting Monitor only, Read only and Guest ambassador on Site levels. The more details are as below
Organization Level is read only
Site Privilege:
• Monitor only
Users can view all of elements under Monitor tabs among AP, SWITCH and GATEWAY and Organization item except for the content of Create site (Greyed-out). However, Configure tabs among devices are invisible to access.
• Read only
Users can view all of elements under both Monitor and Configure tabs among AP, SWITCH and GATEWAY but are unable to modify/perform them. Likewise, they can only see the details in Organization item excluded from the content of Create site (Greyed-out).
• Guest ambassador
The role is used to grant the guest users that are connecting to SSID via cloud authentication. They can only see and authorize/add new user on the page Organization > Cloud authentication.
Organization Level is none
Site Privilege:
• Monitor only
Users can view all of elements under Monitor tabs among AP, SWITCH and GATEWAY However, Configure tabs among devices are invisible and Organization item is greyed-out to access
• Read only
Users can view all of elements under both Monitor and Configure tabs among AP, SWITCH and GATEWAY but are unable to modify/perform them. Likewise, Organization item is greyed-out to access
• Guest ambassador
For more understanding, you can refer to the following matrix table of admin privileges for relationship between Org and Site
I hope this is clear for you
Zyxel Nebula Support
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 300 Service & License
- 483 News and Release
