Multy U (wsr30) issue to connect 2nd node
Kelly
can someone advise, what may I do wrong?
i bought 3 Multy U (WSR30). Installing the primary device through Ethernet cable was smooth, and works fine.
I am trying to add a 2nd node to extend WiFi range. When going through the installation steps, additional Multy is found and connected through Bluetooth, but location checks fails all the time. Already tried in close distance (i.e. 2m), mid-distance (6-7m) and longer distance (10m with wall between); none found connection.
any tips?
thanks!
any tips?
thanks!
Dear Sir,
We have received your feedback from multy app, and we will contact you via email.
Best regards,
Jerry0 -
I have the same problem
Please help!!0 -
Dear Sir,
Best regards,
Jerry0 -
Same problem for me. Seems to be stuck on the location check. Please help.0
Hi @Mollerup,
Could you describe more details about your issue?
1.How do you connect your Multy device in your environment?
2.Which model of Multy device are you using?
3.What is the firmware version of the Multy device?
4.Could you provide us a video related to your issue?
5.Please send us the feedback on the Multy APP.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
