NAS326 bootup very slow ~ one hour
2»
  • Mijzelf
    Mijzelf Posts: 2,918  Guru Member
    Were you suspecting this?
    It's the only reason I could think of why chown -R on a healthy disk and filesystem could take an hour.
    Is this a known (mis-)behavior?
    I don't know. I never heard of it, but I'm not very Plex. I only wrote the installer script, on instructions of someone else. Never used it, except for testing if the installation succeeded.
    Maybe you could ask in a Plex forum.
  • pdpbjorn
    pdpbjorn Posts: 10  Freshman Member
    Yes, I will pursue it in the Plex forum.
    Thank you VERY much for your great help!!!
    Did you manage to resolve the case? I'm dealing with the same issue, NAS326 and Plex » 35-45 minute waiting from turning on to the "beep".
  • pdpbjorn said:
    / $ find /i-data/sysvol/.PKG/PlexMediaServer/share/PlexMediaServer | wc -l
    485990
    in my case its around 80000
  • Mijzelf
    If you can find the leaked files, you can add a remove to the start script. It can't be hard to recognize them, as they must have an auto-generated filename.
