NAS326 bootup very slow ~ one hour
2»
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    Were you suspecting this?
    It's the only reason I could think of why chown -R on a healthy disk and filesystem could take an hour.
    Is this a known (mis-)behavior?
    I don't know. I never heard of it, but I'm not very Plex. I only wrote the installer script, on instructions of someone else. Never used it, except for testing if the installation succeeded.
    Maybe you could ask in a Plex forum.
  • pdpbjorn
    pdpbjorn Posts: 11 image  Freshman Member
    Yes, I will pursue it in the Plex forum.
    Thank you VERY much for your great help!!!
  • hargitanandor
    hargitanandor Posts: 2 image  Freshman Member
    Did you manage to resolve the case? I'm dealing with the same issue, NAS326 and Plex » 35-45 minute waiting from turning on to the "beep".
  • hargitanandor
    pdpbjorn said:
    / $ find /i-data/sysvol/.PKG/PlexMediaServer/share/PlexMediaServer | wc -l
    485990
    in my case its around 80000
  • Mijzelf
    If you can find the leaked files, you can add a remove to the start script. It can't be hard to recognize them, as they must have an auto-generated filename.
