Zyxel LTE4506 Micro-SIM HS
Pastoi
Pastoi Posts: 2 image  Freshman Member
edited January 2024 in Mobile Broadband
Hello, a friend broke the micro-sim connector on my LTE4506 router.
Do you know the reference of this connector in order to change it on the pcb?
#LTE_Oct_2018
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188 image  Zyxel Employee
    Sixth Anniversary
    Hi Pastoi,
    Can you please help to provide a photo for broken sim connector?
    Where you bought this device? Please provide your serial number to me (You can find it in back label of your device).
  • Pastoi
    sn: S162Z42001183
  • YeK
    YeK Posts: 150 image  Master Member
    Hi Pastoi,
    The module is design on broad directly so I think it’s impossible to replace it by yourself. I suggest you can send it back to repair via RMA.
  • Kuky
    Kuky Posts: 2 image  Freshman Member
    Friend Collector
    Hi Pastoi,
    I have similar problem with SIM, how did you access the board? I don't see any screws 😆 And how did you solve your problem?
    Thanks!
  • Pastoi_
    Pastoi_ Posts: 2 image  Freshman Member
    Hi Kuky,
    the 4 screws are at the 4 corners, under the router.
    I still haven't fixed it. If you find the right part, I would love to have the link.
    Thank you.
  • Kuky
    Friend Collector
    Hi @Pastoi_ ,
    thank you for your answer. I found it very helpful. I tried many attempts but everytime failed. So I made it like this. It's working now, but it's a matter of time before it breaks 😔
    PS: that bracket for SIM is not the right part, it's something random which I found on the internet for 4-5$
  • Pastoi_
    Hi Kuky
    well done, the alternative is clever.  =)
    Thank you.  ;)
  • Cricri
    Cricri Posts: 1 image  Freshman Member
    I have the same problem. An exchange via RMA of the SIM support on my LTE4506 would cost approximately how much? Otherwise, for Kucki's solution, how do you remove the old SIM support? What points need to be desoldered?
