No Client Data in Nebula from NWA110AX
All working now. NTP was being blocked on the WAP as the Firewall rule was not setup properly. Thank you for your help.0
Hi @bymusty,
I checked your organization to check the issue you mentioned, but the organization is currently in base pack without cloud-saving now. So, we are checking the time period between your two posts. I'll update for you asap, and if you got the issue again, please clear the cache or use a private browsing on the browser and check it again.0 -
Nebula_Freda said:Hi @bymusty,
Hi Freda .
The organization we mentioned seems to have improved for now. But I have the same problem with all other base pack organizations (about 8-10 units). Although I open the button, cloud saving mode is automatically turned on after a certain period of time. Also, although I tried different browsers and incognito mode, I could not get a result. (Exp Egemen Bilgisayar, Ersa ......)0 -
Hi @bymusty,
Would you let me know the organization name and enable Zyxel support in HELP> Support request of these organizations? We'll check them after getting the information.
BTW, did you clear the cache or use private browsing on the browser before you access these organizations?0 -
Yes I tried it in private browser too. I tried ignorantly. I have the same problem in all base pack organizations that are under my account and have not been logged in for 30 days. I gave support request permission to 2 of them. These are ERSA and EGEMEN_BILGISAYAR. But apart from these, there are 7-8 more problems in the organization.
Hi @bymusty,
Thanks for update detail to us. We are investigating this issue and the local support has already opened a ticket for this case. So, let's keep tracing the issue via the ticket and I'll update on the ticket if there's any progress.0 -
Hi @bymusty,
After investigating, it's a bug for disabling the could-saving mode, so we'll fix it and update for you asap.0 -
Hi @bymusty,
The issue has been fixed and all organizations that the local support reported are disabled cloud-saving mode now. Please check and let me know if there's any problem. Thanks.0 -
Hi @bymusty,
The cloud saving mode disabled failed issue has been fixed, so may I know is there still any problem I can help?0
- 441 Beta Program
- 293 Service & License
