Replace NAS 326 after an electric failure
eabaigar
Hi everybody,
I have a NAS 326 with two 2TB discs working OK till 2 days ago. An storm has burnt the mother board of the NAS.
The question is: Can I buy another NAS326 and insert the two discs in the new NAS326?
How can i access to data in my two 2TB discs?
Thanks.
Edu
Thanks.
Edu
Your disks (when they survived) will be recognized and accepted by any ZyXEL firmware v5 NAS (NAS326, NAS5xx).You can mount the disks on any Linux box. If you have connected both disks you can assemble the array(s):sudo mdadm --assemble --scanMaybe the arrays will be automounted, depends on the exact OS. If not you can mount them manually. The md devices can be found usingcat /proc/partitionsThe filesystem of the data array is ext4.0
I suggest you to backup your data first.
Then you can either buy new NAS, or if your NAS still have warranty do RMA.
Or you can consider replacement of motherboard.
Thanks Podo for answering me, but How can i backup my data?
What is the format system of the Volume_1?
Can I read it whith a Linux OS?
I remember that I setup the discs in RAID 1-
Thank very much0 -
Hi everybody,Finally, on Friday, I received the new NAS326 and after inerting the 2 hard disks, it was very easy to setup the server again. The Volume_1 was recognized inmediatly (it was in RAID 1 like I have setup in the first NAS). I defined the users and permissions again, and in 20 minutes the NAS was working again.Thanks!0
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
