Urgent - need to remove client from block list
Hi @IvanSerra
You could change client’s policy by following steps at Site-wide > Monitor > Clients:
Change the search period to longer days to include the client’s information that you want to edit.
Select the client then click Policy button and Normal, then the client will follow the SSID authentication method to associate.
or click Show policy clients to manually edit the user's information:
Here is an article Client Policy for your reference
https://community.zyxel.com/en/discussion/10022
Thank you
Regards,
Bella
Yes but I can't
Hi @IvanSerra
If you’re using base pack, you can follow the second way mentioned above do it.
Click Show policy clients, select the client then click Policy button to manually edit the user's information.
Thank you.
Regards,
Bella
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
