Connection problem with backup rsync from NSA520 to NSA325v2
SlawekJ
For two years, the backup was performed via rsync, run from the NSA520.
Data was transferred from the NSA520 to the remote NSA325v2 without any problems.
After replacing HDDs in NSA325 with new ones and setting shares, I cannot create any "rsync" or "synchronization" backup job in BackupPlanner because there is an error in connection with the remote target NSA325 (as shown in the picture).
Normal "archive" mode works fine and both NSA520 and NSA325 and their shared folders are visible on the network and work OK from PCs.
Could someone suggest how I can fix it?
Best Answers
Yes you can basically factory reset your NSA325 create new volume for new hard drives.0
Did you install the BackupPlanner package on the 325?Did you create a share on the 325 with read/write access?Can you ping the 325 from the 520 in Control Panel->Network->TCP/IP->Network Diagnosis?0
Maybe you can reset NSA325, create new clean volume for NSA325 and create rsync backup from the beginning.
Sapphire23 said:Maybe you can reset NSA325, create new clean volume for NSA325 and create rsync backup from the beginning.
Sapphire23 said:Yes you can basically factory reset your NSA325 create new volume for new hard drives.
Mijzelf said:Did you install the BackupPlanner package on the 325?Did you create a share on the 325 with read/write access?Can you ping the 325 from the 520 in Control Panel->Network->TCP/IP->Network Diagnosis?
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 465 USG FLEX H Series
- 305 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
