Connection problem with backup rsync from NSA520 to NSA325v2
SlawekJ
For two years, the backup was performed via rsync, run from the NSA520.
Data was transferred from the NSA520 to the remote NSA325v2 without any problems.
After replacing HDDs in NSA325 with new ones and setting shares, I cannot create any "rsync" or "synchronization" backup job in BackupPlanner because there is an error in connection with the remote target NSA325 (as shown in the picture).
Normal "archive" mode works fine and both NSA520 and NSA325 and their shared folders are visible on the network and work OK from PCs.
Could someone suggest how I can fix it?
Best Answers
Yes you can basically factory reset your NSA325 create new volume for new hard drives.0
Did you install the BackupPlanner package on the 325?Did you create a share on the 325 with read/write access?Can you ping the 325 from the 520 in Control Panel->Network->TCP/IP->Network Diagnosis?0
Maybe you can reset NSA325, create new clean volume for NSA325 and create rsync backup from the beginning.
What kind of reset do you mean? Do you mean a factory reset?Sapphire23 said:Maybe you can reset NSA325, create new clean volume for NSA325 and create rsync backup from the beginning.
Unfortunately, the problem persistsSapphire23 said:Yes you can basically factory reset your NSA325 create new volume for new hard drives.
I solved the problem. As you said, after the NSA325v2 hard reset, I still had to install BackupPlanner. I don't know how it's possible that I haven't noticed it before. Thank you and best regards.Mijzelf said:Did you install the BackupPlanner package on the 325?Did you create a share on the 325 with read/write access?Can you ping the 325 from the 520 in Control Panel->Network->TCP/IP->Network Diagnosis?
- 441 Beta Program
- 210 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
