LTE3302-M432 WIFI No internet
Esther
Dear customer service,
I am using a LTE3302-M432 LTE Router, with a Faiba4g LTE Sim card. The connection to the internet is working when using a network wire but is not connected to the internet when using WIFI.
The mobile devices are connected to the LTE3302-M432 but don´t have access to the internet.
Also I´m getting the issue from time to time ip adress obtaining ip adress error.
What causes that issue?
I am using the latest firmware 20181005_Zyxel_LTE3302-M432_V1.00(ABKQ.1)C0 (1).bin
Have the same issue... did you found a way to fix it?
Assume the Connection Control set as Connect-on-Demand and the default max idle time is 600 seconds , the connection will time out in the max idle time. Reverse , set as Auto-Reconnect the connection keep always on. You can check configuration on Management WAN page.
(Go to GUI>Configuration>Network>WAN>Management WAN>Modify>3G/4G Information>Connection Control)0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
