NSA325 opkg TUN driver?
FragsRock
Is there a TUN driver/kernel module for this NAS running with Entware?
The easiest way to get it running is to manually insmod the module with it's full path. Another option is (I think) to create a symlink /lib/modules which points to /opt/lib/modules, but that won't survive a reboot. (Nor does insmod, of course)This modules package was originally an ffp package, and I also provided a patched module-tools package which searched /ffp/lib/modules instead of /lib/modules. I repackaged the modules in an Entware ipk, but never created a module-tools ipk. (Which is in Entware-ng a lot more difficult than in ffp)0
Thanks Mijzelf, you remembered well!
So I installed this with sudo opkg install zyxel-modules-2.6.31.8_1_armv5soft.ipk but modprobe tun returns not found in modules.dep.
Looking around I can see the tun.ko module in /opt/lib/modules/2.6.31.8/kernel/drivers/net and it is referenced in /opt/lib/modules/2.6.31.8/modules.dep but clearly I am missing a step somewhere...
For context I'm trying to get zerotier (or tailscale) to work on the box for emergency use but both fail so far as they can't see a tun module.
Any help appreciated
- 588 USG FLEX H Series
- 477 News and Release
