No Client Data in Nebula from NWA110AX
Zyxel_Freda said:Hi @bymusty,
The cloud saving mode disabled failed issue has been fixed, so may I know is there still any problem I can help?0 -
Hi @JP_atomit,
Is the organization in cloud saving mode? Or, do you mean that the issue symptom is like client number display incorrect? Would you share a screenshot to show the incorrect client number page?
Would you share the organization name to me and enable Zyxel support as below screenshot for us to check detail of your organization/site?
Zyxel_Freda said:Hi @JP_atomit,
Hi Freda. Thanks for the response. Cloud Saving Mode is disabled, the issue is as you described: the tally of connected users on both the AP list and individual AP pages is always zero, even when there are connected devices in the Current Stations list:
The ID for the Org/Site is: 5e3063b90585325209abc4ef/60b0eddd44f7e421f6692e0c I've invited Zyxel support to take a look so if you could tell me what I'm missing that would be appreciated
Hi @JP_atomit,
Thanks for replying detail of the issue. After checking your site, the issue is still happening, so we created a ticket for tracking this issue. I will update for you asap.1 -
Hi @JP_atomit,
After checking detail of the APs, the time is incorrect, so the logs and information are shown incorrect. Please check below firewall information to set the firewall rules and after the AP gets correct time, the client information will be shown correctly.
Thanks for that, I'll pass that back to the guys who manage the firewall. On that note, though, is there any way of specifying an alternative NTP server to use? Either by specifying a public NTP server in Nebula or an internal one with DHCP Option 42 or something like that?0 -
Hi @JP_atomit,
Currently, there's no way to set other NTP server on Nebula AP. The DHCP option 42 is not supported on AP. If you have related request, please let me know and I'll help to created a ticket as a feature request.0 -
Hi @JP_atomit,
Just added your suggestion to WLAN idea in below link.
https://community.zyxel.com/en/discussion/10916/specify-an-onsite-ntp-host/p1?new=1
Awesomesauce - thanks very much!0
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
