Zyxel Auto Repair deleted all files
donixs
I had 2 disks in a RAID config working as a mirror for each other to prevent possible failures.
One day, my NAS 326 started beeping out of nothing so I followed the steps below:
1. Pressed the reset button
2. Went into the Admin area and checked if the disks were ok.
There was a message saying one of them was "degraded" so I clicked the repair button.
Now all of my files are gone.
Can't see any of them!
What should I do?
In the end, both of my WD Purple-line Disks were perfectly fine. I ran a scan and both are healthy.
Yet, 1TB of data, family pictures and files are gone.
Pls help!
What should I do?
Pls help!
Sounds like a filesystem corruption which is repaired. Is the free space in line with the lost files? If not, it is possible that the files can be found in /i-data/sysvol/lost+found/. If all diskspace is available, you might be able to recover your files using PhotoRec, or a similar tool. If you have to go that way, it's important that you don't write anything to the NAS, and preferably switch it off, and connect a disk to an external system.
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
