NAS326 How long to format 12TB hard disk?
grizewald
grizewald Posts: 4 image  Freshman Member
I have just purchased a NAS326 to use as a backup device for my main NAS. I have added a 12TB Seagate IronWolf Pro drive (ST12000NE0008).
How long should it take to format this drive so that I can create a volume on it? It has now been about ten hours since I started the format and it is still running.
  • grizewald
    It seems that the format worked fine, it was just that the web interface did not go back to the desktop when it had finished formatting.
  • grizewald
