NAS542 Raid6 4x6TB - Volume1 used capacity much larger than actually stored
Magne
In Storage Manager Volume1 shows as healthy with a capacity of 10.82 TB, of which 9.98 TB is used.
But a DU command shows that only 2.0 TB of data is stored in my file system,
/i-data/d895772b.
Where can the missing 8 TB be?
In CLI it looks like this:
BusyBox v1.19.4 (2021-04-01 13:06:33 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
~ # df -h
Filesystem Size Used Available Use% Mounted on
~ # df -h
/dev/md2 10.8T 10.0T 863.3G 92% /i-data/d895772b
/dev/md2 10.8T 10.0T 863.3G 92% /usr/local/apache/htdocs/desktop,/pkg
~ # du -c -s -d 1 -h /i-data/d895772b
20.0G /i-data/d895772b/admin
357.6G /i-data/d895772b/TM2020
13.9M /i-data/d895772b/.PKG
610.3G /i-data/d895772b/Backup
26.5M /i-data/d895772b/.media
4.3G /i-data/d895772b/Lydbøker
16.0K /i-data/d895772b/lost+found
92.1M /i-data/d895772b/.system
4.0K /i-data/d895772b/Randi
61.1G /i-data/d895772b/photo
2.3G /i-data/d895772b/music
874.7G /i-data/d895772b/Magne
96.4G /i-data/d895772b/video
2.0T /i-data/d895772b
2.0T total
2.0T total
Best regards,
Magne
Thanks Mijzelf!I followed the instructions to install Entware and busybox 1.33 and found where the spacehog was hidden. Not surprisingly it was in a recycle folder. I have previously tried to free up space by deleting files from the File Browser, but that has only moved them to the recycle bin. I have not found a way to empty the recycle bin from the web gui, so this solution helped me discover where the problem was.Thanks and regards,Magne0
I just found the way to empty all recycle bins in Shared Folders in Control Panel.
- 588 USG FLEX H Series
- 477 News and Release
