NAS542 stuck in a boot loop
Sure.
lovideo could you please explain to me how you could rescue your NAS with the dump file? did you boot via USB or with a serial connection?
You can try the Universal USB Key, in combination with the usb_key_func.sh.telnet_and_stop script, to see if you can login over telnet. However, if the firmware doesn't load at all this won't work, and you'll need serial access.
Dear Mijzelf,i did the following:serial connection went fineexecute env/b1 and this gave a perfect boot into Zyxel Firmware with full access. I thought all problems are solved. then I booted the USB stick with the recovery from zyxel and flashed the original firmware. The result is that both partitions will no longer boot. the serial connection reports that both partitions have an incorrect checksum.
I now have no idea how I can boot the device again. I don't know how to flash the file I received from you. There is no connection over Ethernet.
Can you please help me?
I have nil experience with barebox. Years ago I opened my 540 to see if I could find the serial port, and played a bit with the barebox prompt.When this was uboot, and both stored kernels don't boot, tftp would be the way to go. To do so, you have to install a tftp server on you PC. (That is not an ftp server).In uboot the sequence would be:setenv ipaddr a.b.c.d # local IP
setenv serverip a.b.c.e # IP of tftp server in the same subnettftpboot 81000000 uImage.binbootm 81000000This loads file uImage.bin from the server to memory address 0x81000000, and then boots it. Here you can find a stock uImage, which should be able to execute an firmware update stick, or a univeral USB key.Problems to solve: How to know which ethernet port is used? (Minor, you can try both).How does this translate to barebox? I think the documentation on Internet should tell.
archigraf said:lovideo could you please explain to me how you could rescue your NAS with the dump file? did you boot via USB or with a serial connection?
Okay Thanks
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 78 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 908 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
