NAS320 unable to upgrade to larger hdd size cannot init appliets: [Errorno 2] No such file or direct
How else I could check if there's any physical storage left on the disks?
I can confirm capacity given by SMART and when you hover your mouse over the disk under volume is 14.5TB, not TiB.
14954.00 GB in smart. Wired as with the previous volume I could see them as 16TB and I'm confident they are 16TB, - there's 1.5 TB lost.0 -
pianist4Him said:This is a cat to proc/partitionsThere is no space left.sda is 15625879552KiB, which is 16000900661200 bytes, which is slightly more than 16TB.sda2 is 15625378816KiB, so the difference is 500736KiB which is slightly more than the size of sda1.md0 is 15625377656KiB, so the difference with sda2 is 1160KiB, which is OK for me.I can confirm capacity given by SMART and when you hover your mouse over the disk under volume is 14.5TB, not TiB.
14954.00 GB in smart. Wired as with the previous volume I could see them as 16TB and I'm confident they are 16TB, - there's 1.5 TB lost.Nope. That GB's are actually GiB's. 14954*1024*1024*1024=160567352361000. Where did we see that number before?Conclusion: The script which calculates if an expand is possible, is buggy, and chokes in that big numbers. So ignore the button.
14954.00 GB is given by the Smart reading after I installed the smart package.
Hi Mijzelf,I believe you've nailed it again. I found it does have parted installed and it worked. Indeed, not much free space left:How much free space do you think is left from the parted output below?
Model: Seagate ST16000NM001G-2K (scsi)
Disk /dev/sda: 15259648MiB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number Start End Size File system Name Flags
0.02MiB 1.00MiB 0.98MiB Free Space
1 1.00MiB 488MiB 487MiB ext2 mitraswap
2 488MiB 15259647MiB 15259159MiB ext4 eexxtt44
15259647MiB 15259648MiB 0.98MiB Free Space
Disk /dev/sdb: 15259648MiB
1 1.00MiB 488MiB 487MiB linux-swap(v1) mitraswap
2 488MiB 15259647MiB 15259159MiB ext4 eexxtt4415259647MiB 15259648MiB 0.98MiB Free SpaceAm I correct that there's 1.96MiB free space/unused on each disk (sda and sdb), which minding the 16T, it is very small percentage?
Filesystem Size Used Available Use% Mounted on
/dev/mtdblock6 47.8M 43.3M 4.4M 91% /zyxel/mnt/nand
/dev/sda1 471.6M 464.8M 6.8M 99% /zyxel/mnt/sysdisk
/dev/loop0 135.6M 119.9M 15.7M 88% /ram_bin
/dev/loop0 135.6M 119.9M 15.7M 88% /usr
/dev/loop0 135.6M 119.9M 15.7M 88% /lib/security
/dev/loop0 135.6M 119.9M 15.7M 88% /lib/modules
/dev/ram0 5.0M 4.0K 5.0M 0% /tmp/tmpfs
/dev/ram0 5.0M 4.0K 5.0M 0% /usr/local/etc
/dev/ram0 5.0M 4.0K 5.0M 0% /usr/local/var
/dev/mtdblock4 10.0M 1.5M 8.5M 15% /etc/zyxel
/dev/mtdblock4 10.0M 1.5M 8.5M 15% /usr/local/apache/web_framework/data/config
/dev/md0 14.3T 1.7T 12.6T 12% /i-data/fbf6da57
/dev/md0 14.3T 1.7T 12.6T 12% /usr/local/apache/htdocs/adv,/res/imdb_poster
/dev/md0 14.3T 1.7T 12.6T 12% /usr/local/zy-pkgs
/dev/md0 14.3T 1.7T 12.6T 12% /etc/zyxel/zy-pkgs
/dev/md0 14.3T 1.7T 12.6T 12% /usr/local/apache/htdocs/adv,/pkg
/dev/md0 14.3T 1.7T 12.6T 12% /usr/local/mysql
/dev/md0 14.3T 1.7T 12.6T 12% /usr/lib/locale/locale-archive
I read the same. And yes, that is a small percentage. 0.00001%, when I'm not mistaken.pianist4Him said:Am I correct that there's 1.96MiB free space/unused on each disk (sda and sdb), which minding the 16T, it is very small percentage?
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
