Zyxel nas542 boot loop after installing OMV
faierbol
Hi all,
Can anybody help with a step by step guide on how to recover the original firmware?
I have tried to follow the steps found on this forum on all the threads related to zyxel nas5.. boot loop.
None of them worked
The problem:
I have installed OMV on a SD card and everything was fine until i wanted to expand the sd disk to the entire capacity 64 GB.
After this step none of the firmware's worked and the nas entered in a boot loop.
The nas gets an IP address but the is not reachable over SSH or telnet.
As i said above i have tried everything i found on this forum including the recovery stick, nothing
Current situation:
i have managed to connect to the nas box with a serial connection
i have also tryed b0 b1 b2m none of them works, i get "bad magic number"
i don't have all the command found here on the forum like the one "setenv" is not recognized
I am attaching the printenv output and reset output
None of them worked
The problem:
Current situation:
I don't see how I can help you, as you already tried everything.
the thing is that the steps are not documented and i dont know what i am missing0
do i need to modify anything on the config file or just copy the uimage with tftp on the box and run:
tftp -f uImage.520.bin -a 80010000
bootm 80010000
running the above steps gives me an error related to free space (out of space)0
faierbol said:running the above steps gives me an error related to free space (out of space)Make sure you always switch on the logging function of you terminal emulator. It ensures you can always readback your actions and their response.That 'uImage.520.bin', what is it's source, and what is it's size?
the image is the one shared by you https://zyxel.diskstation.eu/Users/Mijzelf/NAS/542/ and it has 6.99 MB i rename it to uImage.520.bin0
- 244 Nebula Ideas
- 6.9K Security
- 810 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
