User Configuration number of zones
PeterUK
PeterUK Posts: 3,891  Guru Member
Zywall 110
Did the number of User Configuration number of zones from firmware V4.65(AAAA.1) to V4.70(AAAA.0) change from 15 to 14? as when I tried to update the firmware it rolled back so I had the boot to the new firmware and do a reset then load my config with “Ignore errors and finish applying the configuration file” and it worked but when I go and check my setup the only thing missing (so for) was a zone I had 15 I now have 14 if I go to add a zone I get “'Zones have reached the maximum number.”
Best Answers
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,431  Zyxel Employee
    edited November 2021 Answer ✓
    We will fix the issue in the next version of date firmware. I'll send the firmware to you when it is ready.
  • Zyxel_Emily
    The firmware is ready.
    Add 15 user defined zones and upgrade ZyWALL 110 to this firmware.
    No error message appears after device reboots. 15 user defined zones still exist.
  • Zyxel_James
    Zyxel_James Posts: 788  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @dnlk17,
    This zone-fix is added into V4.72C0 already, please refer to the Release note
    Do you encounter this after upgrading to V4.72?
    Thank you.
    Best regards,
    James
«13
