Cant access my NAS326
MatsG
Changed Router a couple of weeks ago, no problem that i know of with my NAS.
Now suddenly this morning it was beeping a lot.
Shut it down, via the power button on the nas because my computer couldnt fint it.
Started it later (beeps 3 times during boot.. a lot of seconds between the beeps), still cant find it.
Using the findme address and then push the sync button, nothing happens.
In my app for my ASUS Router i can see the nas online, with an IP number, trying to use both the ipnumber and the given name to access it, nothing happens.
Any suggestions?
Thanks in advance.
//Mats
Try a factory reset. Press the reset button on the back until it has beeped 3 times (will take 10~20 seconds).
Tried.. reset 3 beeps.. let go of the reset and ther is 3 quick beeps, still the same.
I searched the startscript and found this:#if one sys-root image or kernel is currpt => bootform another sys-rootThis codepath is reached when something is wrong with the flash partitions. Maybe that can be repaired using a 'Rescue stick'. Download the right file here, and unzip it to a fat formatted USB stick. Read the readme, and add the firmware as described. Plug the stick in the NAS, and boot it. It should reflash the firmware.
#if dual sys-root or kernel are currpt => the buzzerc beep forever
flash_fail_handler()
echo "the sys-root image /dev/mtdblock${IMG_MTD} is currupt !!"
I did the reset once more... ALL my files are gone even If I found info that files shouldnt be affected by a reset.
Did you store your files in custom shares? In that case you have to re-enable the shares. A factory reset resets all user config, including shares. But the directories on the NAS backing the shares are still there.
Thanks, that worked ... but not all folder I think... strange.I have some mapped folder to this NAS... one of those folders are still missing.. i dont remeber deleting it... because it is my "Digital Photo Sorted Folder"Any way to see if it is still there?I have 2 hdd on RAID in the NAS, "Volume on RAID" th.ey should be mirrored. Its 2 2TB disc and I only have 2TB
Any way to see if it is still there?Enable the ssh server (somewhere in system->network), and login over ssh (you can use PuTTY for that). Then executecd /i-data/sysvol/lsThe last command should list all your shares, if your lost directory is not there, look if a filesystem check has found it:suls lost+found/
cd /i-data/sysvol/ => ls doesnt show my lost folderis SU a command because it doesnt work "not found"ls lost+found/ = can't open 'lost+found/' : Permission denied0
Yes, su (lowercase) is a command, which gives you the right to read lost+found. (And more)
This is how it looks.after su it asks for pw, i used my ordinary, and that worked.
- 426 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 344 USG FLEX H Series
- 288 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 404 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
