NAS326, MetaRepository not Working Correctly
ceyhun41
ceyhun41 Posts: 2 image  Freshman Member
Hello, I am a Nas326 user. While trying to update from outdated apps, I discovered an alternative repo to the expired Zyxel repos. As you all know, I am using this repo link;
I downloaded the http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/web_prefix file to the /i-data/11dbf589/admin/zy-pkgs file directory for installation. When I refresh App Center, MetaRepository is listed. But my other installed apps are not showing up. I disabled it then enabled it again and the result didn't change. When I ping zyxel.diskstation.eu, I get a successful response.
What is the problem? Can you help me?
List Fail :
Pinging zyxel.diskstation.eu result:
/i-data/sysvol/admin/zy-pkgs/MetaRepository directory:
#NAS_Jan_2022
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    I think the answer can be found in the 2 logfiles. But at the moment the ftp server on ftp2.zyxel.com is down for me. That could be the problem, you can try to put a # before that line in the webinterface, and retry.
  • Mijzelf
  • ceyhun41
    Problem solved, thank you for your help.
  • Fksahin
    Fksahin Posts: 16 image  Freshman Member
    Hello @Mijzelf; I use Plex in my NAS326 and Transmission.
    What apps do you propose on NAS 326 which are useful?
  • How did you manage to access this /i-data/sysvol/admin/zy-pkgs/MetaRepository directory? Which software you are using?
  • Ignore this question, I found out. Best way is via WinSCP.
