firmware gs1910-24 & gs1910-24HP
Hi @mMontana,
The GS1910 series has special situation that it need to follow firmware upgrade flow.
But other devices do not have upgrade flow to follow.
That's why we only publish the latest firmware files of EOL devices on End of life | Zyxel.
Zyxel Melen0 -
I can respect the choice of not providing support for older devices.But be part of the process of not allowing an unpatched, sometimes buggy, sometimes unsure device "alone in a network" without posting into community appears to be another step to create more eWaste.Maybe wanted for sell more devices? IDK. But closing the FTP site still seems by a consumer and specialist perspective a step, but into the wrong direction.Give back to the customers the history of firmware, the documentation. For allowing more re-use of not "mint" hardware if necessary.0
I just wanted to take a second and say thank you for uploading these files! I was able to get my switch updated from 1.00(AAAX.2) to 2.00(AAAX.0)0
I have a (rather old) GS1910-24 (without HP) and would like to upgrade the firmware.
Can I use the files posted by in December 2021 for that?0 -
thanks a lot, that worked perfect!
Hi Melen,
in the EOL List, there is no GS1910. Is the GS1910 EOL? Or is there a newer firmware as 2.00?
Sorry to dig up this old thread, but I just got a used GS-1910 on Firmware V1.00(AAAX.4).
Could you be so kind to post the latest firmware possible, so I can upgrade?
EDIT:
OK, finally found it:
Works like a charm.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
