Unable to connect to NR7101 after firmware update
Tamir
Tamir Posts: 1 image  Freshman Member
edited January 2024 in Mobile Broadband
My NR7101 is installed on the pole about 250ft high. After the last software update and factory reset, I cannot connect to it via LAN. Wifi is disabled by default (might by turned on by clicking on the button, but it is really high.
What to do? How to configure it (it was factory reset upon the firmware update.
  • Miaa
    Miaa Posts: 28 image  Freshman Member
    First Anniversary
    Hi Tamir, you can connect a PC on NR7101's LAN via Ethernet cable(such as NR7101[LAN]<-->PC), and PC perform "ifconfig" on Command Prompt to check default gateway. Then you can access NR7101 GUI with default gateway to configure it.
  • Miaa
    First Anniversary
    Hi Tamir, you can connect a PC to NR7101 LAN(such as NR7101[LAN]<-->PC) and PC check "ifconfig" for the default gateway to access NR7101 GUI to configure it.
