WiFi drops out after a few hours
I purchased a Zyxel NR5101 via Zyxel Amazon a couple of days ago and it came with the following firmware/module:
- V1.00(ABVC.3)C0
- RG502QEAAAR11A03M4G
I set up the device and all appears to be working…
There was a firmware update available via the online firmware upgrade option and so I updated the firmware. It's now running:
- V1.00(ABVC.4)C0
I now have a problem with the routers WiFi connection. After a few hours use both the 2.4GHz and 5GHz bands won’t allow any device to connect or vanish completely. Reboot the NR5101 and the WiFi is up and running again. Yes, I have tried factory resetting the NR5101 but it happened again!
When this happens the phone port still works as do Ethernet connections. So, the router is still maintaining a data connection with my cellular provider. It's just the WiFi that has failed. I don't think it's hardware related as a reboot resolves the problem and all my devices reconnect to WiFi.
I had the WiFi setup as shown below:
Band: 2.4GHz
- Channel: Auto
- Bandwidth: 20/40MHz
- Control Sideband: Upper (Can't change this)
- WiFi Network Name: ***Changed from default to custom SSID***
- Max Clients: 32
Band: 5GHz
- Channel: Auto
- Bandwidth: 20/40/80MHz
- Control Sideband: None (Can't change this)
- Max Clients: 32
WPS is Disabled and 802.11 Mode is set to 802.11 a/n/ac/ax Mixed. All other setting are at their default values!
I have made the following changes to my WiFi configuration in an attempt to resolve the WiFi issue:
Band: 2.4GHz
- Channel: 3
- Bandwidth: 20MHz
- Max Clients: 32
Band: 5GHz
- Channel: 56
- Max Clients: 32
I am now waiting to find out if the changes I have made above fix my WiFi issue. Anyone else experienced this issue?
If I can't resolve it, I will have to return the NR5101 to Amazon for a refund! 😔
Best Answers
Hello @WelshPaul
I don't know if it will help you or if you want to try it, but the ABVC.3 firmware is available at https://support.zyxel.eu/hc/en-us/articles/4403365084818-Advanced-Downloads-for-5G-devices if you wish to try a rollback.
Kind regards,
Tony0 -
Oh my... Rolling back the firmware hasn't resolved my WiFi issues after all! 🤬
It works for longer with the V3 firmware but eventually all of my devices lose WiFi and cannot re-authenticate unless I reboot the router. To clarify, I have fill WiFi signal on both 2.4GHz and 5GHz but nothing will authenticate! Ethernet works, phone port works but WiFi just gives up and crashes after an extended period of use.
I'm returning mine to Amazon for a refund!1
Hello @WelshPaul
Kind regards,
Tony0 -
Hi Tony and thank you for taking the time to reply to my request for help...
I had considered rolling back the firmware but wasn't sure if it was possible as many manufacturers prevent such things. Also, I don't even know if the updated firmware is the cause as I only had the device 12 hours when I got the update alert and updated the firmware.
Anyway, since making the changes I mentioned in my original post everything is working as it should, so I will hold off making any changes for now. If it happens again I will do as you suggest and roll back the firmware and hopefully that will fix my issue. 🤞
Well it just happened again!!!
The WiFi led stops flashing and goes a solid green.
All of my devices connected via WiFi loose connection but Ethernet continues to work just fine.
I have rolled back to:- V1.00(ABVC.3)C0
If it happens again I'm going to return the unit for a refund and get a Huawei.
EDIT: I just looked at the Amazon reviews (NR5101 has a poor rating overall) and someone else has left a review saying that their device also suffered from this issue and so I don't think rolling back the firmware is going to help. 😔
Well after rolling back the firmware to the following version:
- V1.00(ABVC.3)C0
Well it's now March 6th and since rolling back the firmware I have not experienced any WiFi dropouts. 👍
I'm returning mine to Amazon for a refund!1 -
You're going to think I'm nuts but on the 7th, I ordered another NR5101 and it was delivered on the 8th. It also came with the following pre-installed:
- V1.00(ABVC.3)C0
I have returned the original NR5101, and I have received a refund. I did open a support ticket, but they were of no help. They denied that there was a V1.00(ABVC.4)C0 and when I provided screenshots to prove it existed they simply advised me to stay on V1.00(ABVC.3)C0.
So, I have no idea if the issue was firmware related or if the original device had a hardware fault. Anyway, I'm hoping this device continues to provide me with a reliable service.1 -
WOW - So this one is doing the same thing!!! Clearly my original device didn't have a hardware fault after all, the firmware is to blame. I am returning this one too! 🤬1
For me everything released after V1.00(ABVC.6)C0 is unstable.
I have noticed WiFi dropping with V1.00(ABVC.7)C0 and V1.00(ABVC.8)C0.
UPDATE: After Updating my module to RG502QEAACR13A04M4G_ZYXEL and using V1.00(ABVC.8)C0 the WiFi issue resolvedUPDATE 2: Software is full of bugs. I'm done with this. Returning.
I returned mine for a refund. Haven’t purchased any other Zyxel hardware since.
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 919 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 926 Nebula FAQ
- 422 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
