how do i access NWA3560-n GUI ?
jenbo
jenbo Posts: 1 image  Freshman Member
edited May 2024 in Wireless
i have a NWA3560-n and it seems to have FTP, SSH, HTTP and HTTPS open but i cant connect to it ..FTP and SSH just gives me a command promt and http and https does nothing.. i have it connected to my local router  so it gets a DHCP address and thats about it .. NO wifi is enabled on the NWA3560-n so i cant access it that way ether ..i dont understand what im doing wrong
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    Your browser maybe don't trust the kind of TLS/HTTPS protocol your AP is providing.
    Or... if you have it as used device from another setup, maybe it's still part of a managed set of APs.
    So maybe... need a reset before have access?
  • Zyxel_CSO
    Zyxel_CSO Posts: 500 image  Zyxel Employee
    5 Answers First Comment Friend Collector Ninth Anniversary
    Hi @jenbo
    Please test the process below, and you can access the web GUI of your NWA3560-N
    1. Push the reset button of your AP
    2. Upgrade your AP's firmware to the attached file through FTP
    (You can follow the URL below as reference, the approach can be also applied to to 3560N)
    > https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=016149&lang=EN
    After firmware upgrade, your AP should broadcast Wi-Fi signal, and allow HTTP/HTTPS access!
    Best Regards,
    Richard
    Zyxel Nebula Support
