Armor Z2 - can't access router
Drakkarok
in Home Router
Hello. I would like to say that my modem works fine, but my Z2 is getting me some trouble.
In CMD i saw that i did not have any gateway (simply blank there), couldn't connect to the router (myrouter and any other didn't work), couldn't reset it (?) because i held the reset button for 15 sec and it didn't do nothing (also tried to hold it when off and start it while pressed - no response either).
The only thing that i saw it's doing is that i have two cables in it and both their lightnings (the little green lights) are turning on and off in the same time (like they are synchronized).
I run out of ideas, what do you think?
I would say if the device is not working fine after do the reset or the reset button is not working.
I'll do the RMA for the device.0
- 588 USG FLEX H Series
- 476 News and Release
