USG Flex 200 - Detecting APs on DMZ interface
I have a USG Flex 200 firewall which I just installed and configured. Everything is great however I would like to manage my three APs WA510Ds via the USG firewall. Preferred I would like to add the APs to my DMZ network however when I give the APs an IMP in the DMZ they are not getting detected. If I give them an IP within the LAN network then they show up in the firewall. Is there a way I can enable the AP detection on the DMZ interface as well?
Thank you
Marcus
    PeterUK Posts: 3,891  Guru Member
    You need to make a from DMZ to Zywall rule I think for ports UDP 2018 and 5246
  • Mc210274
    Mc210274 Posts: 2
    Hello PeterUK, that worked. Thank you very much
