Multy X permanently blinking white
jeremy_gerbil
jeremy_gerbil Posts: 7 image  Freshman Member
Friend Collector Sixth Anniversary
A Multy X which has worked for several years will now only flash its LED white when starting up, no matter how long it is left.  As it never flashes blue I can't add it back to the network.  It cannot be reset (I understand reset does not work in this state).  Is there any way to fix it?
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello all,
    Looking at the user guide at https://download.zyxel.com/Multy_X_(WSQ50)/user_guide/Multy%20X%20(WSQ50)_V2.0.0%20ed2.pdf it seems that blinking white LED means booting up or doing a firmware upgrade.
    The user guide also says that the RESET button (REST) can be used to do a factory reset when the LED is not blinking white.
    I think like @ikubuf that boot should not take long, but a firmware upgrade might.
    It might be worth waiting even longer to see if the LED does change colour to Blue or Red or non-flashing White.
    Kind regards,
         Tony
  • ikubuf
    ikubuf Posts: 143 image  Ally Member
    Does the press and hold reset button for 10`15 seconds, will the LED light change, or it keep on the blinking white?
    Or maybe you can try to press and hold the reset button before power on the device, after power on and wait for the LED light change, will it work?
  • jeremy_gerbil
    Press and hold reset before power on: the white LED comes on solid, but every 10 seconds or so will flicker briefly.  This repeated as long as I held the reset down - about 3 min.  When I released the reset it continued to do this indefinitely.
    Press reset for 10-15 sec while white LED is flashing on and off - has no effect at all.
  • ikubuf
    edited April 2022
    Can you wait for 5-10 more minutes? Will the LED light still the same?
    As I know, the white LED blinking is under the boot process.
    It should not keep in the boot process for such a long time.
  • tonygibbs16
    Hello all,
    Kind regards,
         Tony
  • jeremy_gerbil
    I had tried leaving it for up to half an hour but following @tonygibbs16 advice I left it overnight.  Bingo, the light is now solid.  Longest firmware upgrade ever?  I will try adding it to the collective again.
