I cannot forward port 80? ARMOR G5 router question!
Now I've bought the Zyxel ARMOR G5 AX6000 NBG7815 router brand new but I can't forward port 80?
Are you serious?
A member of staff told me that it wouldn't work.
I've had a lot of routers and up until now I could do it with anyone.
Why should port 80 be used?
I hope that someone here can help me. Otherwise I have to send the router back.
Thanks!
Sell this garbage and buy something real. I did it the same way. It will not work zyxel is too incompetent to make this happen. I can recommend you to have a look at the Qnap QHora-301W. I use this one and am very satisfied.
Zyxel wants the customer to buy a very expensive firewall for this feature, which is absolutely outrageous.0
They did this on the USG when you have one WAN IP and will not let you port forward 80 because the web interface uses that port unless you change the interface port or use port group to get around it and it seems they done it to there home routers too are you able to change the interface/remote port?
Does DMZ forward the port if it has DMZ?
Just another over sight by zyxel or they want people to buy their USG routers.
If it happens to have a config backup in plan text you could edit it for port 80 and upload it.1 -
"are you able to change the interface/remote port?"
I can put the router on its own port, which I have already done.
However, that doesn't help either.
I don't think he has a DMZ.
I think that's absolutely cheeky.
You pay 330 for that thing and you can't forward the port. Any other mid-range router can do that.
I did not find any such function. I'm getting really annoyed. I think I'll send that thing back right away.
Hi @cuterex,
Armor G5 can’t make port forwarding from the system reserved ports.
However, you can make port forwarding from another port to internal port 80.
Example:
Port forwarding from Armor G5's 8888 to internal port 80.
Hi @PeterUK,
Thanks for your feedback, it could be considerable to leverage to USG series rather than Armor G5.
We will put this idea in idea section for our future development evaluation.
@Zyxel_Can My God, the support didn't understand it either.
A browser listens to port 80 and not 8888 etc.
So I also need port 80 from outside. Is that so hard to understand?
Sorry, but every 10 € router can do that.
But Zyxel is all about the money and you want to pull people over the table or how does it look?
That's how I see it.
PeterUK said:
They want to earn more money is clear. Just cheeky for this price. Any other router can do that. It's an absolute joke. I have now bought a new one from another company. There is no reason why port 80 should be used!0 -
G1 has this issue too.
Having the ability to make the web interface accessible from the WAN side of the router is a terrible idea. That is just asking to be hacked. Just eliminate that and 80 would no longer need to be "reserved for system use".
If you would like to block the access from wan site, there is an feature under System> remote access> Access interface, select LAN and the router can only access with LAN interface.And yes, I think it need to be eliminated the 80 port.0
- 438 Beta Program
- 183 Nebula Ideas
- 6.2K Security
- 449 USG FLEX H Series
- 301 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 434 News and Release
- 91 Security Highlight
