NR7101 B20+N1 Hangs
Kennyblu3
i have a issue with the NR7101 Router. I am connected with Telekom in Germany with the B20 and N1 Band. I am on the newest Firmware Version V1.00(ABUV.4)C0
and the Modul Version is RG502QEAAAR11A03M4G. The Problem is the follow, under load the Router stops working. I cannot ping the router anymore , or connect to the gui. It is reproduceible with a simple speedtest. The Router will only come up again if i disconnect it from power. I have already reset the router, but it dont help. I cannot find anything in the logs.
Sorry for writing this thread i'm not a Zyxel expert, but I have the same issue.
Just I wanted to mention V1.00(ABUV.5)C0 firmware is also affected with the same Modul firmware.
Hi!
Latest firmware is ABUV.5, download it and try more....
https://www.dropbox.com/s/og7h04hzdb58sfh/1.00(ABUV.5)C0.zip?dl=0
We experience the same thing (Netherlands) that the modem stops working after a few hours. We are going to lock the modem on 4G to see if the problem persists.
With the new/latest firmware the issue is still there.
Hi
Same problem with NR7101 on ABUV.5 here in switzerland...
What can we do?0 -
Same problem with Telenor (Yettel) network in Hungary...0
I have install this modem version RG502QEAAAR11A06M4G it is more stable. But not fixed to 100 % .0
I have RG502QEAAAR11A07M4G installed and PCI SCAN works fine.0
SELBERG said:I have RG502QEAAAR11A07M4G installed and PCI SCAN works fine.
Happy Easter everyone.
Kind regards,
Tony0 -
No from another place..... Could not update from 3 to 7, first 3 to 6 and then 6 to 7.....
Here is a screenshot from my scan, dont know if it works on 5g...........
I have this same issue. Have tried all firmwares up to 1.00(ABUV.5 and several modem updates. Connectivity just stops for no reason.
Reboot or switching 5G to 4G helps.
Log:Apr 14 15:17:30 daemon.info dnsmasq-dhcp: sendLeaseMessageToESMDApr 14 15:17:30 daemon.debug dnsmasq-dhcp: sendLeaseMessageToESMD send to esmd buf = {"ac":"add","expire":"465182","mac":"xxx","ip":"xxx","host":"*","vendor":"*","moui":"*","serial":"*","pclass":"*","cid":"xxx","ifname":"br1"}Apr 14 15:17:30 daemon.debug dnsmasq-dhcp: sendLeaseMessageToESMD esmd ret=1Apr 14 15:27:30 daemon.info dnsmasq-dhcp: sendLeaseMessageToESMDApr 14 15:27:30 daemon.debug dnsmasq-dhcp: sendLeaseMessageToESMD send to esmd buf = {"ac":"add","expire":"465782","mac":"xxx","ip":"xxx","host":"*","vendor":"*","moui":"*","serial":"*","pclass":"*","cid":"xxx","ifname":"br1"}Apr 14 15:27:30 daemon.debug dnsmasq-dhcp: sendLeaseMessageToESMD esmd ret=1Apr 14 15:37:31 daemon.info dnsmasq-dhcp: sendLeaseMessageToESMDApr 14 15:37:31 daemon.debug dnsmasq-dhcp: sendLeaseMessageToESMD send to esmd buf = {"ac":"add","expire":"466382","mac":"xxx","ip":"xxx","host":"*","vendor":"*","moui":"*","serial":"*","pclass":"*","cid":"xxx","ifname":"br1"}Apr 14 15:37:31 daemon.debug dnsmasq-dhcp: sendLeaseMessageToESMD esmd ret=1
Please support.0
- 395 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 82 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 415 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
