NR5101 control via Webside
Fremmed
Just installed NR5101 wi-fi router. Got access to the system via LTE Aly. Cannot access by website with correct login.
Why?
Why?
Yes, LTE Ally works more less ok (means that you don’t have total overview of your router).
The problem now is with website login.
192.168.1.1 doesn’t work.
Its impossible restore password.
What is wrong?
Was having the same issue and realised the solution was to login to the nebula dashboard which displays the password in Site-wide > General settings > Device configuration.
Not sure why this password is different from the one on the label. Rather annoying.
- 439 Beta Program
- 2.8K Nebula
- 206 Nebula Ideas
- 522 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 290 Service & License
- 4.5K FAQ
- 98 Security Highlight
