Plex for NAS326
Mijzelf said:That is the same error as this guy had, so I suppose Plex changed something nasty. I suggested to use the Netgear package instead, and he never came back, so maybe that is the solution.
I get the same error, and have tried several other packages - including the Netgear. Nothing works... Do I have to contact Plex to get a solution to this? Is there another workaround? Any suggetions will do at this point...
Edit: I made a post in the Plex forum, asking for some guidance. If I'll get an answer I post it here.0 -
I tried different packages, the result is the same.dystophia said:Mijzelf said:That is the same error as this guy had, so I suppose Plex changed something nasty. I suggested to use the Netgear package instead, and he never came back, so maybe that is the solution.
I have the same problem, did you find a solution?dystophia said:Mijzelf said:That is the same error as this guy had, so I suppose Plex changed something nasty. I suggested to use the Netgear package instead, and he never came back, so maybe that is the solution.
I have successfully installed Plex, but I would like to add a plugin. I am unable to find the plugin folder on the NAS326.0
Assuming such a folder exists, it should be somewhere in /i-data/sysvol/.PKG/PlexMediaServer/share/PlexMediaServer/Don't know how Plex plugins work, but if it are binaries, they should be compiled for Armv7.
Sucessfully installed.
Latest NAS326 firmware
Synology package:
PlexMediaServer-1.26.0.5715-8cf78dab3-armv7neon_DSM6.spk
Plug-in directory:
/i-data/sysvol/.PKG/PlexMediaServer/share/PlexMediaServer/lib/Plex Media Server/Plug-ins#
Plex does not see the plug-in. Thanks for trying to help.0
Hello everyone,
Today 2024 I was fighting with installing plex server on my Nas326 and heres the result:
1.32.8.7639 is the newest versions which is working. you can download it here:
Hi everyone, I can't install the plex server, it always gives me an unknown command. How can I solve it? Thank you
- 234 Nebula Ideas
- 6.7K Security
- 722 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
