Jason
[NEBULA] how can connect GS1920-8HP to NCC
Hi @Ambato,
If the CLOUD LED status is blinking Amber, that means the Switch doesn't connect to NCC.
Please check if the Switch has already connected to the Internet.
You may access the Switch via Telnet and ping 8.8.8.8.
Hope it helps.
God morning nebula jason
Thank you for the anser.
The switch work properly, Internet acsess very good only nebula controllpanel show me switch is offline.
Greetings from switzerland
Ambato0 -
Hi @Ambato,
Thanks for your information.
To identify the issue for more detail, I will PM you later.
Please check your Forum Inbox.
Jason0 -
I'm having the same issue with the same product.Zyxel_Jason said:Hi @Ambato,
Switch connected to internet but Cloud led blinking amber, and nebula controlpanelshows me it is offline.
Thank you0 -
Hi @dyn_dan,
Welcome to Zyxel community!
There might have DNS resolution issue or connecting port been blocked.
You may check this topic to troubleshoot your issue first:
How to simply troubleshooting on my Nebula Switch?Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
