User Configuration number of zones
Zywall 110
Did the number of User Configuration number of zones from firmware V4.65(AAAA.1) to V4.70(AAAA.0) change from 15 to 14? as when I tried to update the firmware it rolled back so I had the boot to the new firmware and do a reset then load my config with “Ignore errors and finish applying the configuration file” and it worked but when I go and check my setup the only thing missing (so for) was a zone I had 15 I now have 14 if I go to add a zone I get “'Zones have reached the maximum number.”
Best Answers
Hi @PeterUK,We will fix the issue in the next version of date firmware. I'll send the firmware to you when it is ready.0
Hello @dnlk17,This zone-fix is added into V4.72C0 already, please refer to the Release noteDo you encounter this after upgrading to V4.72?Thank you.Best regards,James0
Hi @PeterUK,Add 15 user defined zones and upgrade ZyWALL 110 to 4.70.The error message appears. We are investigating this issue.0
Test the firmware can now get 16 thanks0
Hi @Zyxel_Emily,
I think I have the same issue with my USG40 and the 4.70(AALA.0)C0 firmware, when upgrading to this firmware version, the configuration gets rolled back to the default one.
When "force-"applying the configuration (using this approach with the 3rd option: https://support.zyxel.eu/hc/en-us/articles/360006181614-Avoiding-configuration-corruption-crashes-on-firmware-upgrade-downgrade-Setenv-Script-) on the 4.70 version, there is then at least one zone missing.
Is it possible to get a similar .bin containing the patch as for the ZyWALL 110, but for my USG40?
Or, when will be the next firmware release for my device?
Thanks & kind regards,
Daniel
Hi @dnlk17,Here is the latest firmware with the solution.0
Zyxel_Emily said:Hi @dnlk17,Here is the latest firmware with the solution.
thanks for providing the link to the patched v4.70 in January.
When upgrading to V4.71(AALA.0) while having 16 zones (7 custom + 9 default), the problem seems to happen again.
-> "Boot Status:Previous firmware update failed!"
The system error log says: "Previous firmware upgrade failed - ERROR: zone CLIENT_LAN"
So my question is if the new v4.71 also contains the patch from "zld-v4-70-wk46"?
Thanks and best regards,
Daniel0 -
Zyxel do their fixes in such a way you have to wait for a main release vs patches for vulnerability at least that how I understand it so
4.70 is main release
4.71 is patch
4.80 is main release
But I just removed some zones till its in the next main release.
Hi @dnlk17,The official version 4.71 is a urgent release that only contains vulnerability fixes.Please upgrade to this version to solve the issue of "User Configuration number of zones".0
Thanks a lot @Zyxel_Emily for providing a patched version containing the zone-fix!
Also thank you @PeterUK for enlightenment regarding versioning strategies
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
