NWA90AX
Welcome Zyxel Community,
According to your question, don’t worry and it is not caused by AP setting. It looks like the device’s behavior that sends the warring message when defect new network devices, Maybe you can be based client OS or system to search the pop our message.
Of course, if you need our assistance, please provide the client and OS info for us. we are glad to help you to resolve your question.
Wish you have a good day
Zyxel_Jay
Hi, thanks for your response. Issue happened e.g. with my iPhone. One App is from Pioneer which is for the connection to my receiver, message: Network error, one other App is IQControl NEO which is as gateway to home automation, message:"Error"... (not very helpful at all). How can I check, it not only my iphone tell me its connected to the network via NWA90, can I check with Nebula if there is "real" traffic?
additional information: it takes general a long time to connect my iPhone to NWA90. If I stand directly in front of the device, the status LED is blue, the I connect with iPhone, LED switch to green and it take >2min. to connect. On NWA1123 it only take seconds...
Thank for your response.
OK,We will check your AP log on Nebula to clarify this problem.Could you kindly help us to turn on your Zyxel Support Access from the below path in your nebula?
PATH: Help (Left sidebar corner)>>Zyxel Support request >> Zyxel Support Access>>enable invite Zyxel Support as administrator
Please make sure both of your AP(NWA90AX and NWA1123) online.Then please tell us your org&site name, AP mac address,your iphone mac address(or station name on Nebula),you can PM me if you don’t want to show personal information in public.
We'll check the problem as soon as possible.SincerelyZyxel_Jay0 -
you got a PN0
We have seen your setting and event log on Nebula .
We found your environment has the the other AP uses the same SSID, the logs show it roamed from other AP sometimes. Please help to check your environment or change other SSID do to further test.
Thank you
Zyxel_Jay
Please check again, NWA1123 has SSID "Zyxel_EG", NMW90AW has SSID "Zyxel_OG", they are different since the beginning...
Hi Markus_Bavaria
Good day
In your event log, we saw the roam log. (We PM the log picture for you)
Is MAC your other AP NWA1123-NI?
And we also saw the intra-roam log, your device frequently roams from 5G to 2.4G
It causes your device can’t connect to AP immediately.
We can adjust the Radio setting first.
PATH: Access Point>Configure>Radio Settings
1. Adjust Maximum Output Power > Change Custom --> High-Density Deployment
2. Disable Smart Steering
Sincerely
Jay
Dear Yay,regarding MAC I sent you a PN.Radio Settings are done0
Good day,
We have seen your logs and it looks like a bug we are handling.
We turn off/on your AP radio setting. Can you kindly help to test again whether the issue still happens or not?
On the other hand, can you share your AP NWA1123 diaginfo ? We want to check the roaming log question.
Zyxel_Jay
- 213 Nebula Ideas
- 555 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
