NR7101 does not accept Username and Password after factory reset
BrandSafway
Hi Zyxel Team,
i have setup a Zyxel NR7101 and upgraded it to the following device and modem module firmware successfully:
Router Firmware: 1.00(ABUV.5)C0
Modem Firmware: RG502QEAAAR11A07M4G
After having just changed some wifi settings it started to reset the WAN connection every 30 seconds and kept kicking me out of the configuration page due to "network change detected".
I then followed with a factory reset on the device. Pressing the button for 15 seconds.
Now im faced with the issue when i try to login via http://192.168.2.1/login
i keeps saying username or password wrong.
Username: admin
Password: 1234
i have also tried the default password that is printed on the label and worked with the initial setup. It run the factory set twice. Still facing the issue that the username/password is wrong.
I'm unable to login into the configuration page.
Please advise. Im unaware of any new default username/password shipping with the above firmware!
Regards!
Try a power off for a minute.0
thanks i tried that. in the end the problem was that the default password had an "a" that printed on the label looks like an "o". after factory reset it's accepting only the default password despite the guides saying after factory the default will be "1234"
Lifesaver, thank you. Just bought an used NR7101 and after factory reset couldn't log in with admin/1234 which was printed on the sticker. This did the trick.
Hi, I have same problem. I did factory reset and could not log in with admin and password which is printed on the sticker. Tried also power of, no luck.
SN: S220Z41000659
FW: 100ABUV8C0
Modem code: RG502QEAAAR11A06M4G-R11A07
This is not ISP owned NR7101 like the support SN check said :)0 -
You need to power off 2 minutes, not just a few seconds!
I understand, it was off like 15 min.
case closed, seller had put his own soft , what had diffrent ip and psw than the sticker
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
