NWA50AX + Nebula WIFI password is rejected, iPad,Iphone
Hi @PEACEkeeper,
We would like check detail logs for your nebula site,
but your Nebula support is exipred and please help to us to enable Zyxel support again.
Thank you
Zyxel_Jay0 -
Hi @Zyxel_Jaybut your Nebula support is exipred and please help to us to enable Zyxel support againI've enabled the support invitation again.
Best Wishes,
Frank
Hi @PEACEkeeper
We have received your log on 6/9 1:21.Here is an abnormal log related to Tx/Rx information, It looks like a bug and we will do further investigation and try to fix it as soon as possibleWe suggest to disable 802.11r first until we provide the solution.Access point>>Configure>>SSID Advanced settings
Zyxe_Jay0 -
Hi @Zyxel_Jay
thanks for your advice.
I've disabled the option as suggested and will be looking forward for an update.
I hope, that this will temporary fix the problem.
I't would be great if you leave a comment in this thread when a fix is available.
Have a nice day
Frank0 -
And when a official firmware will be available.
Hi @mMontana @PEACEkeeper
Good dayThe official firmware version 6.25P10 is released on Nebula.Please refer to below to get the release information.Please feel free to upgrade your APs firmware.Let us know if you want to ask anything else.
Sincerely
Zyxel_Jay
Good day, we have uploaded new firmware to Zyxel.com.
There are NWA50AX, NWA90AX, and NWA55AXE firmware official hyperlinks.
Thank for your response
Zyxel_Jay
Hi @Zyxel_Jay
Thanks for the information.
I've updated all APs and reenable the 802.11r support.
The problem seems to be solved
Best wishes
Frank1 -
I am having the exact same issue on my NWA50AX. I am running standalone mode with the latest firmware.
My devices cant connect to the wifi in the morning because the password is rejected. Connecting my device to a different SSID and then connecting the device to the original SSID again seems to be a workaround.0
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 497 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
