Remove an internal HDD of a NAS540 and install it on a external USB case
MarkusDesk
MarkusDesk Posts: 31 image  Freshman Member
edited June 2022 in Personal Cloud Storage
Hello, if I remove a basic volume HDD from a NAS540 and put it on a external USB enclosure and connect it to another NAS540, how can I mount it to copy the files?
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    Find out which device node is used. Probably 'cat /proc/partitions' can tell you.
    Assuming the disk is sdd, you can mount it:
    mdadm --assemble /dev/md4 /dev/sdd3 --run
    mount /dev/md4 /path/to/mountpoint
    When /dev/md4 is already in use (/proc/partitions or /proc/mdstat will tell you) choose a higher number.
    A warning: some (maybe most) USB to Sata converters do a logical sector size translation on disks >2TiB. If your enclosure is one of them, this will not work, as changing the sector size renders the partition table incompatible. You can see if this is the case with 'fdisk -l /dev/sdd'. It shows the logical sector size, which should be 512 bytes.
    On modern kernels it is possible to create a loopdevice with a deviating sector size:
    losetup --sector-size=512 --show -f /dev/sdd
    now you can treat /dev/loopXp3 as /dev/sdd3. But I doubt if either the kernel of the NAS5xx or the (busybox) implementation of losetup supports this.
  • ybaumbach
    ybaumbach Posts: 1 image  Freshman Member
    edited June 2022
    On modern kernels it is possible to create a loopdevice with a deviating sector size:cookie clicker
    how to find out which device node is use? I'm quite blind about this stuff
  • MarkusDesk
    edited June 2022
    Hello, thanks for replying.
    With the command cat /proc/partitions, I get:
       8       32 7814026583 sdc
       8       33 7814025543 sdc1
    With the HDD connected on the USB enclosure and with the fdisk -l command, I get:
    Disk /dev/sdc: 7.3 TiB, 8001563221504 bytes, 15628053167 sectors
    Units: sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Device     Start         End     Sectors  Size Type
    /dev/sdc1   2048 15628053134 15628051087  7.3T Linux filesystem
    So it seems to be 512 bytes, correct?
    Before I try the command mdadm, I want to make sure I don't mess with anything. After the mdadm and mount command, can I just umount it and remove the USB drive or do I need to issue another command?
  • Mijzelf
    @ybaumbach : 'cat /proc/partitions' shows you the disks, their partitions and sizes. If that is not enough to distinguish the USB disk, you could look at the difference without and with the disk plugged.
    @MarkusDesk : There is something wrong. If that disk contains a volume created in a NAS5xx, it should have 3 partitions, not just one.
    But yes, the sectorsize is correct. (Although I doubt the optimal I/O size is 512 bytes, but that won't affect the basic functioning)
    After umounting you can stop the array:
    mdadm --stop /dev/md4
    I don't think it actually matters, but it won't do any harm, and it look symmetric.
