Multi X and Mini
Gert
Gert Posts: 1 image  Freshman Member
I have a Multi X and Multi Mini in a daisy chain configuration connected wirelessly.
On the X which is wired to the modem receiving the fibre line I get 450Mbps on 5G Wifi, but on the mini which is located in my office I only get 100Mbps.
Is there a setting to change this?
  • ikubuf
    ikubuf Posts: 143 image  Ally Member
    Try to move your mobile/laptop closer to the WiFi router and check the speed again.
    In case of suspected interference – move your mobile/laptop to different places and check the speed.
    You can find which place has more good signal.
    Or move your extender node to other places and see which places signal is more stable and efficient.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited July 2022
    According to the Multy Mini User Guide available at https://download.zyxel.com/Multy_Mini(WSQ20)/user_guide/Multy%20Mini(WSQ20)_V2.2.1%20ed1.pdf there is a way in the Multy App to check the Diagnose the speeds of the Multy Site, including the speed between the Mini and Multy X.
    This might show you if the speed is being restricted by the Mini and Multy X or not, maybe because of the distances between them.
    With Multy X and Multy Plus, you can apparently do a daisy chain of devices to extend the WiFi range, but you cannot daisy chain with Multy Mini or Multi U according to the User Guide.
         - you can only connect Multi Mini directly to the Primary Multi that is connected to the Router or Modem.
    I hope that this is helpful.
    Kind regards,
        Tony
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @Gert,
    Can you provide us with the topology of your Multy network?
    How do you get the result 100Mbps?
    Can you provide how you do the testing? Does the result always limit to 100Mbps?
