Connection troubles with NR7101 after every 24 - 48 hours
You don't need vanilla OpenWrt, you can use ROOter, which is an openwrt fork for modems.
And no, it is not hard, but the guide on the official forum is not totally correct.
I made a guide for installing ROOter and upgrade firmware, which is the same as openwrt, just vanilla openwrt doesnt have anything to control modem, ROOter have an easy menu where you just set apn, and connection monitor, and you are done. But you have to use MBIM mode, because in QMI, on openwrt you don't have QMAP, so anything over 150 Mbit/s will overflow the cpu, and crash the modem.
It will be up on youtube soon, so if you want, you could get ROOter, or if you prefer, you can install whatever modem firmware you want, whitout needing Zyxel Dfota file.0 -
n_o said:u3000 said:I'm fine with Openwrt on my NR7101 here. It has a cron job to daily reboot and the package "watchcat" installed which resets the modem in case 4 pings in a row fail to a specific host in order to bring the net online again.
does openwrt support ip-passthrough ?
what country are you ?
You can DMC and avoid double nat anyway, so no need strictly the ippassthrough0 -
It will be up on youtube soon, so if you want, you could get ROOter, or if you prefer, you can install whatever modem firmware you want, whitout needing Zyxel Dfota file.can you link to the video once uploaded?also is it possible to revert to stock firmware after?0 -
And sure, it's really easy to go back to stock firmware. you also retain all the config you have on stock firmware when you do.
Actually it's the best way to get module firmware upgrade, and the only one to get R13 firmware, which adds 5G CA.
you just hop on ROOter, instal module firmware, and get back to Stock firmware. that's it.1 -
let me know when you have uploaded it. i would like to have a test run. i have a spare Zyxel which i can use for testing.
are there new about that guide ?
Hi all, most likely the reason for connection drops and traffic freezing is the fact that NR7101 lacks functionality to automatically re-connect to better signal or 4G when 5G signal gets too weak. This is standard feature in every other device.
To reconnect, boot is required..0 -
Anybody got a script that would watchdog the connection with ping and reboot as needed? I tried to look for a solution but couldn't find one.
I currently have uptime of 15 days without any issues. It certainly is possible with better signal levels..2
I've just stumbled across this thread and it looks like this is the issue we're struggling with at one of our client sites.
I'm replying because we have managed to get ours to reconnect without a reboot. This might help you guys, but you may also find this triggers a thought process that maybe could help us all.
The way I got ours back online was this - I logged in and noticed that the active SIM selector was set to 'AUTO'. We only have a SIM in slot 1. So, I set it to use SIM2. Then set it back to SIM1. The connection came up immediately.
My hope was that maybe the system was inadvertantly tripped up by the option of having the 2nd SIM slot available. I thought that perhaps removing this option might prevent it going wrong again. It's a bit early to tell as this was only 2 days ago.
If anyone has any ideas, I'd love to hear them. I may also look into the firmware management systems that have been previously mentioned although I'm not massively keen on the idea :-/0
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 213 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
