exFAT usb drive MOUNT
jin08611
it seems that the NAS540 cannot MOUNT exFAT formatted USB drive automatically?
I was in the terminal -- and it seems that it has "mount.exfat-fuse" in the sbin folder?
Can I mount manually???
# mount -t exfat /dev/sd[x] /i-data/sysvol/exFAT_USB_DRIVE_name
??? is anyone know if this is going to work?
thanks
JIN
thanks
JIN
AFAIK it should mount automatically. Did you check dmesg for errors, or did you try to mount manually? It won't hurt.
I will try it again in few days I am currently uploading all my files to this new NAS I will post my findings in few days
THANK YOU for all your awesome answers mijzel!!!
: 0
- 588 USG FLEX H Series
- 477 News and Release
